2002 Ford Explorer Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you turn off the oil change message in the 2002 ford explorer after the oil has been changed?
Marvin
Level 3:
Top Expert:
  • Ford Master 85,242 Answers
  • Posted on Apr 15, 2009
Marvin
Ford Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025207
Points
266281
FROM YOUR OWNERS MANUAL:
To reset the oil monitoring system to 100% after each oil change
[approximately 8,000 km (5,000 miles) or 180 days] perform the
following:
1. Press the SETUP control to
access the System Check function.
2. Press and release the RESET
control to display “OIL LIFE XX%
HOLD RESET NEW”.
3. Press and hold the RESET
control for 2 seconds to display “IF
NEW OIL HOLD RESET”.
4. Press and hold the RESET
control to display OIL LIFE SET TO
100%. Your oil life is now reset.
To reset the oil monitoring system to your personalized oil life %:
HOLD RESET NEW”.
5 Related Answers
A
Anonymous
  • Posted on Jul 09, 2008
SOURCE: Ford Explorer Oil change rest message
no...not helpful at all really awful .
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 15, 2008
SOURCE: 2006 Ford Explorer "Oil Change Required" light is still on after changing the oil
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
Anonymous
  • 1056 Answers
  • Posted on Aug 13, 2009
SOURCE: fuse number for turn signals on a 2002 ford explorer sport trac
It should say it on the fuse box cover. Unless you dont have the fuse box cover anymore.
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Nov 04, 2009
SOURCE: How 2 turn off "oil change required" lite
Ford Explorer, Mercury Mountaineer, 2002-06
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed.
Ford Five Hundred, Freestyle, Mercury Montego 2005-06 Tap the ODO/TRIP button to toggle the display between the odometer and trip odometer. Tap on the ODOiTRIP button again to toggle the display between the trip odometer and OIL LIFE % display. Press and hold the ODO/IRIP button for 2 seconds or more to display OIL LIFE 100%. Your oil life in now reset.
Good luck and print this and keep it in the glove box. Keep me posted if you have any other questions
Anonymous
  • 108 Answers
  • Posted on Jan 31, 2010
SOURCE: 2002 ford explorer V8. Car was running great had
check for loose connector particularly the crankshaft sensor near the engine drive pulley.or fuel impact switch tripping but this is not a PATS problem since the starter cranks.
Change oil transmission ford explorer 2002 4x2
i know you cannot check your transmission fluid like years prior to the 2002 they made this model so you have to take it into the shop/dealership to have them check your levels, and change the transmission. They are trying to eliminate the backyard mechanic from doing maintenance on the vechicles
2002 ford explorer with 137,000 engine just yesterday began to knock. Oil is ok,
Sounds like a piston knock due too not having a oil change previously
My change oil display on my 2005 ford explorer i changed the oil and it wont go out
Press your reset button on the on board diagnostics which is located on the dash, keep pressing the rest button until you see "oil life" once you come to the oil life, hold the reset button until it reads "Oil Life 100 percent" release the reset button, shut the vehicle off then re start it, that will turn off the message in the message center telling you to change your oil.
2helpful
After oil change the warning light ( Oil change required ) still ON
You need to reset it manually after you change the oil. If you have the owners manual it will explain how to do this. If you don't have it you get get a PDF version online at ford.com.
2006 Ford Explorer owners manual.
Essentially you need to scroll through the message center until system scan appears. enter it and a message will come up oil life press reset if new or oil life hold reset if new. Follow those instruction and the oil life will eventually change to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Buying a 2002 ford explorer 4.0 liter, how do you change transmission oil
Remove the trans pan,same as most vehicles
have always been
If it has not been changed every 30,000 miles,
do not buy it
Power Steering Fluid as well
5helpful
2answers
How do you reset the change oil message on a 2007
Ford Explorer, Mercury Mountaineer, 2002-07
14helpful
3answers
2helpful
Changed oil and message center still says oil change required (2002 mercury mountaineer)
Oil change reset 2005 explorer
  1. Press and release the SETUP button until the message center displays PRESS RESET AT OIL CHANGE.
  2. Press and release the RESET button until the message center displays HOLD RESET TO CONFIRM.
  3. Press and hold the RESET button for 2 seconds and release to reset the oil life to 100%.
Oil change message
reset the message center
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
