Make sure the machine is unplugged. On either side of the green motor housing there will be a black plastic disc. Using a medium to large sized flat headed screwdriver turn these anti clockwise until they are fully removed. You will see the back of the brush inside, and all you need to do is hook them out gently. If the carbon part is longer than about 5mm on each one then they should be fine.
