SOURCE: machine wont stop filling with
Same thing happened to my ASKO W600. Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine. Check it out and replace if necessary.
SOURCE: replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
