SOURCE: Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
SOURCE: Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
SOURCE: mY SONY BRAVIA FLAT SCREEN HAS A LINE ACROSS THE
Sounds like someone hit and broke the screen. Not repairable and not a warranty claim...
Testimonial: "not your fault that Sony robbed me blind with crappy product"
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
