I have the same problem. Usually the problem occurs when the laptop has went to sleep/hibernate. It will power on (backlight, keyboard light, etc.) but blank screen. The screen will also shut off but the computer still runs and keyboard operates (I've heard windows sounds when using it even though screen is off). Extremely annoying and has caused me so much lost time.I have the same problem. Usually the problem occurs when the laptop has went to sleep/hibernate. It will power on (backlight, keyboard light, etc.) but blank screen. The screen will also shut off but the computer still runs and keyboard operates (I've heard windows sounds when using it even though screen is off). Extremely annoying and has caused me so much lost time.
You can't post conmments that contain an email address.
It it is located at the bottom of the device.. Flip over your Zenbook carefully, and on the bottom side there will be one or two small flap doors with a screw in it the memory is under one and the HDD Drive is under the other.. Be sure to shut down and take battery out before you change or take out memory or HDD Drive.. Hope this helps.. Ian.C
Hi Ahkeema Hill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
elaborate this more clearly please
what are you doing on the laptop,.
a web site messed up.
no model Zenbook told
is it all of windows messed up.
or one part
or login pages locked up.
why use 'decrypt' word, in what context?
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
As you said u have just brought your laptop.. does it have any warranty if yes go and repair it for free.. if no warranty then All I can suggest is that your problem seems to be Bios related. To get into the bios screen you have to use F2. F8 is usually for getting to the boot order - make sure you have Windows in first place and F10 saved. If you plan on updating the bios to the current latest 214, bear in mind that there is no going back once let loose. I have it on mine and it is OK. thanks
hi only an opinion looks like you might have a hdd failure, if you try sarting in safe mode normally pressing f8 after initial startup and you get 0disks repeated message hdd may have failed.very common problem
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
