Daewoo DW500M Top Load Washer Logo
ieja azam Posted on Sep 13, 2013
Help me ...! My washing machine showed E9 code
Help me ...! My washing machine showed E9 code while there is still water in the tub washing machine, but the machine stopped suddenly. can anyone help me with this problem? Sanyo ASW-D101HT top loader.
Marko
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 13, 2013
Marko
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1591
Points
Adjust the clothes in the machine
Testimonial: "I've already took out all the clothes and just left the water in the tub...but still appear E9 when on-off and start the machine."
4 Related Answers
Anonymous
  • 72 Answers
  • Posted on Feb 26, 2007
SOURCE: washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Anonymous
  • 770 Answers
  • Posted on Aug 02, 2008
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Anonymous
  • Posted on Jul 10, 2011
SOURCE: I have a DAEWOO DWF-1150P top loader washing
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
What does E9 mean - it showed up after about 4 years?
Let's GUESS it is a Samsung or a Sharp!
What does the E9 code mean? This code indicates that there has been a leakage of water from the tank into the drip pan. If the pressure switch detects a 4-time drop in water in the tank, the machine will stop working and the code E9 will be displayed.
Error E9 - Samsung washing machine
https://www.youtube.com/watch?v=tsxi6eKavWQ
My Washing Machine Daewoo DWF 200P Displayed ( E9 ) in screen
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Daewoo Washing Machine Error Fault Codes
https://removeandreplace.com > 2015/11/02 > daewoo-...
Nov. 2, 2015 - The Daewoo generalized error fault codes below are to give you an "idea" as to what part is at fault. ... Daewoo Washing Machine Error Fault Code = E9 ... If your Daewoo Washing Machine Error Code is not listed here, check ... Mine is Daewoo washing machine DWF-8288, showing E1 and won't spin and ...
My washing machine is a Sharp Ess119 model, come out with E9 and doesn't work, can assist?
E9 error code means pressure sensor failure. This sensor is used to know water level in the tub. The problem with the sensor requires a part replacement. IF under warranty have it serviced by a factory authorized service tech.
1helpful
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
2helpful
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
I have a defy top loader washing machine model DTL115. When powered it is writing E9 as a fault.
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
73helpful
7answers
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
1helpful
What dos E9 stands for?
would have helped to know the brand.
But here is the general reference for all washing machines displaying this error
error E9 means a problem with your water pressure sensor. do you have water in the tub? check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open .
Please rate my help++++Thanks for using FIXYA
1helpful
4answers
Washe machine problem
Top Daewoo Washing Machines Experts
Paul Bade
vince
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
