Notes about using USB
= Before using this function, make sure that you select the correct source (USB) and insert a USB storage device on
the TV to view compatible photo, movie and text on the TV screen or play compatible music through the TV.
= If the connected USB HDD does not have an external power source, it may not be detected. Be sure to connect the
external power source.
= To avoid losing the data on your USB device or damaging your USB device, it is recommended that you back up your USB
device data.
= The USB multi media playing menu may vary in different situations.
= If you want to pull out the USB device, please exit USB mode first.
= For instructions on using your USB device, refer to the owner's manual for your USB device.
= Never remove the USB device or turn off the TV while using the USB device. Doing so may result in loss of data and/or
damage to the USB device and/or TV.
= Certain types of USB devices may not be compatible with this TV.
page 21 also shows hitting USB button on remote (lost that?)o
and see photos on a USB or a movie. Photos , movie or text it tells.
here is my wild guess on the model.
https://www.manualslib.com/manual/918457/Sinotec-St-29me70h1.html?page=23#manual
the TV has multimedis player inside, this works for USB.
page 26 covers what movie FILE formats work.
format the usb stick as Fat32 is one safe first guess and try.
good luck with using USB. (the manuals on TV are very very limited on (what it needs to work right)on this TOPIC.
one poster back 2014 this brand
tells. supports fat16/32,and NTFS. and JPG,PMP and PNG photos. and what page 26 tells you,.
