SOURCE: Downloading Camcorder to PC
I've learned my lesson and will share it. Use firewire and try WinDV. Best of luck.
SOURCE: Lost Cable
These are generally a standard mini to Firewire cable, available at many retailers, take your camera with you and look at the available cables. Panasonic has them for sale as well.
http://www2.panasonic.com/consumer-electronics/support/Supplies-Accessories/Cameras-Camcorders/Digital-Camcorder-Accessories/Cables/model.PV-DDC9
SOURCE: need to connect my panasonic pv-gs80 to my imac
Best buy has brand new ones, or you could surf the web and find a cheaper one at like amazon. Just make sure that the size of the cable matches up with the size of your computer or else it will not be able to plug in.
The problem I have is like the other people, I got the firewire in the port and DV on the camera and my computer just doesn't recongnize it. Where's the solution to this? I have been trying to edit my film for over a year now with troubles with losing wires and now this and stuff. Hope this helps
SOURCE: LCD broken Panasonic PV-Gs 320
Hey, all.
I also have this problem, but have a little more to add:
Here is a website that carries the lcd screen: http://www.pasc.panasonic.com/Epartr/PartsList.asp
I think that its the following part number:
L5BDDYH00022
LCD DISPLAY (MONITOR)
87.56
$87.56 sucks, but it could be worse. Problem is now, I'm not sure how to replace it without taking the entire camera apart.
Let me know if someone does this successfully.
Thanks!
EAL
SOURCE: How to connect Panasonic GS-36 to PC
Your camera has a 4 pin port on the side of it next to the USB port.....depending on the type of firewire connector on your computer will determine what type of 1394 cable you will need to connect the PC to the camera. Your computer could have a 6 pin or 9 pin connector (I'm betting it has a 6 pin). Get a 1394 cable that is 4 pin to 6 pin and you should be able to connect the two together....that's how I did it with my tower PC and to my laptop with a firewire PCMCIA card.
