SOURCE: checking the gas and oil levels?
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: i have a coleman powermate 6250 generator it get
Lets see, Do you have any ether or old school lighter fluid? If you use ether spray a little into the air intake just before you pull the cord for a start, if it starts you have a carb problem. Same for the lighter fluid, remove the spark plug and squirt a small amount down in the cylinder, again if it starts you have a carb, probelm. Take the carb. off the engine take note of the rods and springs, take a picture get it in good focus so you can put it back together. Take the fuel bowl off the bottom of the carb and clean the jets and all see if that will help.
SOURCE: vertex 7500 not generate energy
Have you let it set for a long period? I have heard that if you do not use a generator that it will simply stop working(generator portion itself). Make sure no breakers are tripped and the wiring looks OK.
