SOURCE: screen cracked
Id contact LG for info on a replacement screen, might cost alot.
If you have warranty maybe that would save you, but im not sure does warranty repair something caused by the user.
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
SOURCE: LCD has lines and big cracks on screen! Help! My 1st flat screen!
that is a cracked LCD display. Wierd if no one elbowed it or so.
You can try through LG to get a new display for the TV but it will not be cheap
HERE is service manual for it
SOURCE: tv damage
My mothers 42' flat screen TV got knocked over. Now there is a large crack on the inside corner. What would it cost to get it fixed. Please contact me at [email protected].
SOURCE: LG 50PG20 Plasma,, nothing shows on screen its all black
This model was known for issues with the Y-sustain, Y-drives, and the Z-sustain boards. These boards help process the picture image to the screen.
When one or more of these boards fail, the screen stays black, and you only have audio & on/off.
You could call LG and try to get your TV repaired at a discount if you can convince LG to honor this known issue.
Another issue could be the actual panel has gone bad. The plasma panel in your TV has a two warranty and LG would fix that for free. Well…it would be free as long as it’s not past two years of your date of purchase.
What zip code are you in?
