Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work,test that it get power. In case it get power and doesn't work, it should be replaced. Good luck!
