The change actually has to be made with your cable/satellite service's remote control. On the cable remote you should have a #hd zoom button. On the satellite remote it may be format, aspect, or a setting within the menu. The cable/satellite box's menu will also have a setup section where you make sure the resolution is 16:9 1080i fixed. Make sure to disable the 4:3 override as well. Then you use the button on your tv remote to further adjust it with cinema, panoramic, full, or zoom.
Hello: Seem you are in zoom mode, try hitting the format putton on the televisions remote and if you are using a cable box and using HD check for a picture format or aspect button on it also. You will want to be on 1080i normal or stretched. The cable box and television will use different modes for aspect, try using only one of the remotes when changing aspect ratio buttons or screen size.
I have the same tv. On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
Download the service manual and you'll find that there's a service mode that allows you to adjust convergence. Also, there's some adjustment knobs behind the right front speaker assembly
skilled,senior tech needed to access servicer
mode and check/adjust geometry/convergence.
if unresponsive,then replace convergence and
re-check geometry and alignment.
