Disney DTD1363-CAR 13" TV/DVD Logo
Posted on Apr 16, 2009
Disney DTD 363-Car 13" tv/dvd
I have the disney tv and the problem is, watching T.V. with my grandkids and the T.V. just keeps turning off by it self. Now it won't stay on!!!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
200
Points
I have xfinity Comcast cable connected to my Disney's CARS TV/DVD combo. I did not have a remote for it because I bought it at yard sale without it. I used Comcast's remote control. I followed their "Searching For Your Code" instructions. #1-turn on your TV. #2-hold SET till red lite blinks twice. #3- enter 9-9-1. The red lite blinks twice. #4-press nd release the CH+ key until TV turns off. #5-once it turns off press SET key nd red lite will blink twice. #6-Now u have locked in ur code. Press power and TV should turn on. Then CH+,CH-,VOL+, and VOL- should work for ur TV.
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Jan 17, 2008
SOURCE: Disney c1320ptvd-car change sound system BG to DK
c1320ptvd
LANGUAGE SETUP MENU
select preffered language
AUDIO LANG
mini disks must contain the preffered language otherwise they play the preselected language.
user manual found in greek language.
http://www.winlink.gr/data/files/DISNEY%20DVD%20C1320PTVD-CARS.pdf
Anonymous
  • 916 Answers
  • Posted on Jan 06, 2009
SOURCE: My Disney TV has a parental lock and I forgot the password
The parental lock code is 1369. I had the same problem and this worked for me. This for most disney tv's. If not let me know and I will continue to help.
Anonymous
  • Posted on Mar 09, 2009
SOURCE: dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Anonymous
  • 563 Answers
  • Posted on Jul 11, 2009
SOURCE: replace remote for disney princes p1310atv tv?
Look on the back of the TV or in the back of the manual and you'll see the name of the company that manufactured and/or distributed the TV, or you may find a telephone number listed in the manual. You must contact the manufacturer to find a replacement remote for that TV. Universal remotes don't work because that set is actually made by a small company that doesn't communicate with universal remote makers.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Anonymous
  • Posted on Aug 10, 2009
SOURCE: pixar disney cars tv turns on but shuts off after about four secs
another review determined it to be the High Voltage Circuit and cost them $71 to fix.
1helpful
I have a Disney Cars DVD player and I need to set up a universal remote control (its a RCA universal remote) I need the code for the Disney Cars DVD player to do this . I cant watch any DVD's until i...
This tv was produced by some small company for the Disney Corporation,so there are no universal codes out there for this tv.100% i'm sure have original remote.Try website like Remotes.com to buy the original remote.
When i turn the t/v on, it comes alive for about 5
may be you have problems with mechanism of DVD, check if open and close properly if it is not, replace belt and try funtion.
4helpful
2answers
What Brand is a Disney Pizar Cars Tv?
Starlight Marketing Limited - 1 866 387-1902.
Disney Cars TV-Model DTD1363-CAR 13" TV/DVD
I have 1 , exact same problem. I took it to a local repair shop and it turned out to be loose connections on the circuit board. It was explained to me that as the problem became more frequent it was the connections getting worse. It cost about $100 (give or take).
3answers
Disney DTD1363-car, Need part # of transistor
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
3helpful
c1320ptvd
LANGUAGE SETUP MENU
AUDIO LANG
Sound system DK for Disney c1320ptvd-car
c1320ptvd
LANGUAGE SETUP MENU
AUDIO LANG
2answers
Car tv dvd turns off
We have a DTD1363-CAR 13" tv/dvd it turns off after a few min.
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
