Question about Acer Computers & Internet
0xc000007b error fix win 7
Windows narator error at startup
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
MICROSOFT WEBSITE
Posted on Jan 01, 2014
2 Suggested Answers
6ya staff
SOURCE:
rakesh rana
  • 23 Answers
SOURCE: All I get when I boot up is a picture and virus window? Keyboard useless
u need to format ur window
Posted on Dec 31, 2011
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
0xc000007b error windows 7
Hard drive or data error. Try and run chkdsk/f
Generally just running chkdsk/f will fix this error. its normally down to bad sectors on a failing hdd corrupting data.
if your hdd shows more than 1% errors get it replaced as its failing. if its just the odd soft error then full formatting. may solve the problem if chkdsk/f doesn't.
Jan 29, 2014 | Computers & Internet
Assassin creed 4 0xc000007b error
Download Reginout to fix 0xc000007b error simply with some couple of clicks.
Jan 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
This is an application error message; There are many software titles tha experience this error message; Such as Microsoft Office; Visual Stuidio to name a couple. I need more information to point you to the correct solution.
When does the error occur? What were you doing at the time the error message appeared?
Sep 20, 2013 | Toshiba Computers & Internet
At startup windows narator give error 0xc000007b
If you have installed a network card, uninstall any software you installed for it, then shut down your PC. Uninstall the network device you are having trouble with and boot your computer into safe mode (Power up the computer and IMMEDIATELY begin to tap the F8 key SLOWLY about ONCE PER SECOND until you see a menu, then STOP. Use arrow keys to select safe mode then press enter) to see if it will start correctly. If windows starts in safe mode, the reboot. If windows starts normally, there may be a problem with the driver software (download new drivers) or the card itself is bad, and windows chokes on it. You may wish to try and install it again, but that is your call. I would try a different adapter.
Sep 16, 2013 | Acer Computers & Internet
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
Computers & Internet Logo
94 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
