A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
