Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
Does anyone out there in tech-world know the exact amperage for the two fuses in a Philips 37"LCD TV model 37PF7320A? The fuses are approximately 1 inch long with the following markings: T5AH 250V (ceramic fuse) & T1AE 250V ( glass fuse. I am assuming that T5AH means 5amp & T1AE means 1 amp.
  • 3 more comments
  • cyberdark Nov 09, 2007
    I have the exact same problem red flashing light no power
    does replacing the fuses work and where can I purchase these fuses?
  • vickp Jul 24, 2008
    My T.V worked fine until this morning. When i turn it on it flashs the green light and then just blinks red. Tried to turn it on three or four times this morning and same thing happen
  • fluhrerchip Aug 09, 2008
    I have a 50 in plasma that blew an 8am 250 v fuse , I cant find a replacement for. The fuse is only 20mm x 5 mm anybody know whwr to purchase thistype of fuse?
  • Anonymous Mar 15, 2014
    Sharp lcd 20 inch lc-20b6u Where on the board can I find the main fuse and does it have to be soldered in place I can see on the board were it says make sure to use the same marked fuse but cant locate what are the fuses and if they snap in or are soldered in Thanks
    Sniper:
  • 140 Answers
Yes,you are correct.
Posted on Sep 16, 2007
  • 90 Answers
5 amp and 1 amp - slow burn fuses -- they have them at radio shack under 3 dollars for a set of three
Posted on Feb 22, 2009
It is a 5amp fuse but it's a time lag fuse, i.e it wont blow when you hive a minor power spike so you might find that a normal replacemnt fuse kepps blowing
Posted on Mar 06, 2008
6ya staff
SOURCE:
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips LCD HDTV
The unit is trying to start and can not. It then enters protect mode. This means that there is a problem and a full turn on would further damage the set. It should be blinking a code, this code will tell you what the exact problem is. If you call Philips at 1-888-PHILIPS, they can tell you what is the exact problem.
To figure out the code, count the number of blinks.
If you need further help, please ask, but I can't tell you what to exactly replace without more information.
Thank you and have a good day.
Please don't forget to rate this solution
Apr 07, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips HDTV error code
Changed power board and it is working. Has been for about 1 hour.
Dec 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
General Electric LCD 57 in. HDTV .
have power board / supply checked -- also check fuses on board first before you spend any money
Oct 22, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Service Manual?
hi!you can get the manual at http://www.retrevo.com/support/Philips-37PF7320A-TVs-manual/id/278ci358/t/2/
you may  have to make a fast and free registration..
hope u get ur TV working fast!
regards!hope i could help you..
Oct 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Is the fuse in the plug okay?
If the fuses are not blowing when you are turning the tv on, this suggests that the PSU primary side is okay.
Since you have opened the TV up, I would suggest probing around with a multimeter however I do not want to let you harm yourself or the TV.
Look for any:
http://en.wikipedia.org/wiki/Capacitor_plague
on the power supply
Aug 13, 2008 | Prima CV1311 TV
Phillips 37pf7320a 37in.hdtv-ready lcd
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 16, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
3,622 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
