SOURCE: I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ?
or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
SOURCE: I have a Ricoh Aficio 551 copier with the Booklet
Hi, According to your problem. Don't keep any pin or metallic things inside it. Adjust your paper size properly. Don't use wet & damp paper. keep the paper properly on the paper try. you can follow the mannual of the printer.
SOURCE: I have a Ricoh 551 Copier with the Booklet
I was able to locate a service manual that should help you. It has sections for the folding mechanizm and how to adjust it. I would write it all out here for you, but sometimes pictures are better then words and this service manual has both. The manual is not Ricoh 551 specific, but it is compatible with the unit so the instructions should be the same.
http://www.download-service-manuals.com/download.php?file=Ricoh-1903.pdf&SID=qjp21rph66d0tbsukcfvbn2fccofefr5
Regards,
Chris
