Question about Westinghouse SK-32H540S 32 in. LCD TV
Tv turns on, have audio, screen is very bright with very faint video. can use remote and adjust settings but it is still way too bright and video is still very faint in the best configuation with settings.
  • Westinghouse Master
  • 4,048 Answers
Screen inverter fault or could be the bulb in the screen or the inverter is self.
Posted on Sep 17, 2013
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: No video/audio when pressing remote control or on the TV set
Moved my TV to another satellite receiver.
I received picture & audio.
Then I moved the TV back to its original position.
Now it works OK.
I probably hit a button that shut off my picture & sound.
I am mystified.
Thanks anyway.
Gerry............................;-))
Posted on Apr 14, 2009
Lg TV would not turn on, no stand by light. I purchased and installed a power supply. The TV turns on, has audio but an extremely faint picture
Your problem is inside the TV - probably the video driver board or components of it. You also could have a dead fluorescent tube - that is the part that illuminates the screen. LCD displays require a light source. If this is an LED TV then you need a video driver board inside the back of the TV - if you don't know what you are doing, DO NOT OPEN THE BACK OF ANY TV. Take it to a repair shop. If it is under warranty, turn it in for service.
Feb 02, 2018 | LG Televison & Video
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
My samsung turns on, audio is okay but black screen
dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture?
Mar 28, 2013 | Samsung LN52B750 52 in. LCD TV
Screen black, no video have audio. Went black at some point when I was distracted. Have tried unplug/pause/repugnant - no help. On/off did nothing either.Vizio, Mdl- VO320E, LCD. Not listed on your...
You need to perform the flashlight test. Turn off the lights in the room, turn the TV on, take a bright flashlight and shine it on the screen. Do you see the faint image on the screen?? You could have a defective backlight inverter, defective power supply, or a main board issue. You set will require diagnosis to determine.
Jun 04, 2012 | Televison & Video
I just got a Mitsubishi WS-A65 that has a issue, when I turn it on I dont get a picture, I do get some faint glow and some faint curved lines, I get error cod 1-2 which says no error and I have...
Hi, if you have audio and any kind of a blank/darkened screen then you either have a bad video hookup cable, defective video input, or a bad backlight system-bulb or power supply to bulb is probably weak from symptom you described. Hope this was of some help-if you can find a You tube of someone adjusting brightness you may be able to blindly hit right buttons to turn down brightness then turn set off then turn back on with a picture again-it's actually not impossible to do, I know because have actually done it once. Good luck, prodzilla
Mar 31, 2011 | Televison & Video
Hi my sony vio vgn txn 15p video is faint
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
Dec 09, 2010 | Sony VAIO VGN-TXN15P/B Notebook
Sound is operating correctly ..However, there isn't any video , screen has an extremely faint picture
Sounds like a broken backlight. That's a write-off for an old set, or a factory warranty repair (90 days labor, 1 year parts). First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
You can also try adjusting the brightness from the MENU.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
Oct 14, 2010 | Haier HLT71 7 in. Portable TV
Picture too dark
mkbowen,
whats the brand name of your TV?
also try this, facing the front of your screen. locate a button indicating " menu" and click it.
once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
cheers ,
mark
Jan 18, 2009 | Quasar SP-3233 TV
Tha display screen is dark, shows very faintly.
Can you be more specific ?
The first step is to isolate the system at fault:
1) Monitor hardware ?
Test it on another PC or
Try a different monitor on the same PC
Check monitor adjustments.
Check the video cable, try another one.
2) What kind of a monitor is it?
CRT (like and old TV) or an LCD flat screen
3) Video card problem, possible but not as likely
4) Video driver or operating software settings issue
wrong video mode, video settings the monitor can't handle,
incorrect device driver
lots of possibilities here.
MJS
Apr 18, 2008 | Computers & Internet
MUSTEK 7" pORTABLE dvd PLAYER lcd PROBLEM
You might need to adjust the settings by pressing the LCD button then using the up/down/left/right arrows on the player or remote to change color or brightness. If this doesnt work, your screen might be shot. There isn't much you can do if thats the case.
Nov 03, 2007 | Mustek MP70C Portable DVD Player
Westinghouse SK-32H540S 32 in. LCD TV Logo
100 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
