Im trying to use the scanner on this printer and it is asking for a program. I don't fave the disk that came along with it. Can you provide me the system so I can let it run and scan with my computer?
I need to install or run device soft ware. Where do I get itI need to install or run device soft ware. Where do I get it
AnonymousNov 23, 2008
i download a software hp psc 1610 all in one turn out 1600, but i could print but not scani download a software hp psc 1610 all in one turn out 1600, but i could print but not scan
every time i try to use the scanner on this thing it says "you need to run or install device" and thats it.every time i try to use the scanner on this thing it says "you need to run or install device" and thats it.
AnonymousMar 29, 2009
same problem,I now found out on google that hp 1610 buttons do not respond to vista,you have to scan through 'paint" click on the MSN logo on bottom left hand corner,click proggrammes,click accessories,then click paint,you can scan from there and then e mail out or save
You can't post conmments that contain an email address.
after alignment process it asks to put the alignment sheet on the scanner glass .. are you putting it rite way ??? try putting it other way round.. it should be facing down also
I don't want to know anything. I want, (wanted) you to attempt what I had suggested. I am not positive it will work and I did not want you to score me low but would rather have no score at all.
1. Disconnect the Printer/scanner
2. Uninstall the software. START- CONTROL PANEL -either ADD AND REMOVE PROGRAMS or PRINTER AND FAXS _ Highlight printer and tell it to REMOVE PRINTER.
3. Hook the printer back up. Run the install software that has the correct driver for the version of windows that you are using.
The HP link for your model that I provided to you is to download the software to install , if you ether have the wrong driver or have lost the install disk ,if you ever had one.
Look at what version of windows you are using and see if the disk states that it is for that version of windows, like Xp, VISTA, 98, etc. If it does not you must download the correct software.
I was attempting to avoid asking all of the needed questions such as;
Is this a new problem or have never had the scanner work correctly?
New computer or same one?
Computer Make and model?
Version of windows that you are using?
All of these things enter into a problem such as yours.
I hope this helps. |:)
