Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
either your tine shaft is seized to bushings which requires total dissassembly of unit or you have a failure of drive chain or gear i'm currently repairing one with the seized bushings if you are not a technician i would recomend replaceing unit very costly to repair in any case.
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
