Sansui DTV3200 32" TV Logo
A
Anonymous Posted on Sep 16, 2013
Rca mr 29v276 - Sansui DTV3200 32" TV
Programming a RCA system link 3 remote to a westinghouse digital tv
Hi there!!
Try this:
Step 1 Turn the component, like a TV set, on.
Step 2 Hold down the "Code Search" key on the SystemLink 3 remote until the light that's on the remote turns on. Keep holding the button after the light turns on.
Step 3 Press the device button ("TV" button) at the top of the RCA remote. Then, release both buttons.
Step 4 Press "Off/On" repeatedly as the remote browses through available codes. Continue doing this until the component shuts off.
Press "Enter" to save the code.
Good Luck!
Mr.Mike
tip
I gotta tell you...oh boy... you saved me a bunch of money. Right now the U.S....
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
My rca smart TV apps aren't working model SLD50A45RQ
You should make sure you have an active internet connection and that the tv is in a spot that is not receiving interference. Are you able to select any apps? what do the say when you try and use them? Did anything happen prior to the apps not working?
If you need further help why not ask an expert?
https://www.6ya.com/mr.mike
How to fix my rca TV.
Main chroma processor IC fault. Replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
I need a owner manaul
Since you neglected to specify the model of your RCA ViSYS 2-line system I can only suggest you select it from here to download a copy of the manual.
I have a JBL MR 15 does this radio have a place in the back to plug in an ipod adapter. I think it is an Aux input RCA Jack The radio is on my boat and not near for me to look at it.
if it has aux input rca's, then go to an electronics or car audio shop and buy a "stereo rca to 3.5mm headphone jack adapter cable" This will then plug into the headphone jack on the ipod.
2answers
1helpful
Philips Magnavox MRU2600 Remote Control with RCA TV (cable)
0704,0002,0406,0007,0011,0611,0811,0312,0514,0720,0102, 0502,0601
08 17,0917,0835,0901,0103,0803,0211,0912,0114,0519,0320,0420
Estos son todos buena suerte.,
How can i remove the muisc from my opal rca mp
There are several ways. One way is to delete the songs using Windows Media Player.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
