Ink pump motor may be not working first you need check your cp is original.. After that remove drum unit disabled the unit and clean ink detection sensor and ink pump motor
Inside the master disposal box is a black pressure plate. It cannot see the home position sensor. Remove it and check where the flag is for that plate. When properly repositioned it will operate again. Also, master sure that the disposal box set sensor is not popped out of its mount.
I will need more details from you.There is a drum unit in there and a fuser unit that might look like a drum. ans normaly the paper sticks to the hot roller in the fuser, if the lead edge is solid black
