Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Pull the center knob strait off. I
suspect the center shaft of the knob is broken. If it is order a new knob but
before replacing it make sure the shaft on the timer does not have a metal
sleeve from the knob remaining on the timer shaft. Temporarily you can try to
use needle nose pliers to turn the shaft to see if the washer works.
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
You don't give the model or any info. If it is "older" chances are you need a new settings knob or can clean the contacts inside if you are capable of removing it. Other than that check the obvious like cord/plug, spin button, that type of thing.
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
