Question about Ricoh Office Equipment & Supplies
Ricoh SG 3110dn, SC 20200
HELP!! Only had this printer for 3 months. Expanded our printing business to offer Sublimation. Got off to a great start. However, had a death in my family and we haven't been working for approx 6 weeks, but came back to work a few days ago and commenced with the sublimation. All been going well, until i printed a black image, it came out with lines and more of a grey than a black. I performed a nozzle check to find all the colours are perfect except for the black, it missing loads, i then performed 3 head cleans, doing a nozzle check after each clean and it seemed to get worse after every clean. I then tried the Head Flush! After performing the head flush it came up on the LED display saying "Call Service if Error Reoccurs, SC (20200). I've lifted the flap on the top of the printer to see the print lines, and the black line is empty, not clear, more like a browny color. Any Advise would be great, it's a matter of urgency as i have lots of sublimation to do. Thanks
    New Friend:
I have a Different type of Ricoh it's Aficio SG 2100N and the Error is (SC 20200) everything seem okay but it's still showing the error...please help me fix it
Posted on May 12, 2017
    New Friend:
  • 4 Answers
You need change ink collector unit.
Ricoh SG 3110dn, SC 20200 - ricoh-sg-3110dn-sc-20200-bsx1mooyrjt2alicfc0patgd-2-2.jpg
Posted on Jan 08, 2016
6ya staff
SOURCE:
Anonymous
SOURCE: Black Ink Skipping
If you open the printer so the cartridges move to the center and lift the gray handle so you are able to pull the printer head out. Chances are when you do... you will see all the corrosion. Just clean it off and you should be good to go.
Posted on Dec 05, 2007
Anonymous
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
Anonymous
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
Anonymous
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
Anonymous
SOURCE: Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Posted on Mar 11, 2010
How to fix the error sc 20220
If the error you are talking about is SC202, then you have a laser problem. You will need to either replace the Polygon Mirror Motor or the complete Laser Unit if it comes as one assembly.
Jun 14, 2016 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
57000 error
hi
please my SG 3110DN printer came up with this error code : SC 57000
Jan 06, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
9,545 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
