SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
SOURCE: Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
SOURCE: I have a Kyocera Mita 1635 Copier and it's giving blank copies
it may be the problem of moisture dont worry take brasso(used for shining the mitallic products) and put out photo conducting drum and clean the dum with brasso by using a soft cotton cloth ur problem must be solved
SOURCE: HI there! Our Kyocera 180
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit
and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
SOURCE: Kyocera 3035
if ti is a print from machine memory and not from glass the charge is durty the remove charge unit aboth drum and see if there is not durt on the charge wire or on the grid wires the green charge cleaner aboth the wast toner may also have come of and now staning on the rong place , if that is right your laser **** glass behide the drum may be durty if its a copy the small glass onther the document feeder is durty some copiers have a document feederthat have a scanner on the inside oppen the feeder lift the green lever and you fined a small glassin there that need cleaning and last o yes and last do this first open your left side door look at the drum if there a line on the same place than on the paper the drum blade does not clean it and a peace of paper may be stuck betweenblade and drum
