Two blinks denotes an over-current protection. If you wish to get more details about the blinking codes to Sony TVs, check this site. Details are there. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
SOURCE: Sony Bravia TV, stays on standby with a flashing
power supply/ in uk look up ohm supplies to repair it
SOURCE: Sony KDL-40S4100 Bravia LCD will turn on for like
B+ over current protection (OCP), unit goes to the standby mode then
displays the 2 blink fault. Could be a short in the power
supply of any of the
circuits.
