Sansui DTV3200 32" TV Logo
A
Anonymous Posted on Sep 19, 2013
Does a sansui I DTV have a digital converter - Sansui DTV3200 32" TV
1 Related Answer
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Feb 16, 2009
SOURCE: is my sansui sdtv 3200A dtv ready?
SDTV The "D" means 'Defenition' not Digital, S is for 480i. You will need a convertor box. Sorry.....
Sansui to DTV converter box
The model number you provided is for the Sansui tv remote. Are you trying to set up a universal remote that works with your new tv?
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
1helpful
No tv reception
Ur tv is analog tv u know that right?U have pay cable or other pay tv services hook up to ur tv?All CRT are analog tvs and no longer able to recieve free air tv signal reception without the converter box.It all digital now,analog,CRT tvs to get DTV must have a converter box.
Do I need a converter box with this TV to get digital chanels
Do I need a converter box. NO . This does have a Digital tuner .DTV 2760
5helpful
DTV1300A Sansui is not dtv ready, Am I doing something wrong?
To put your digital channels into the memory of the DTV1300 or 1900 press the MENU/ENTER button. Go to CH SETUP. Press the VOL + button. Go to TV CABLE. Use VOL+ button to set to TV for antenna or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL+ button. Wait for the search screen to go away after the analog and digital searches finish on their own. Check ALL your channels with the CH up button. I hope this helps you.
Is my sansui sdtv 3200A dtv ready?
Converter box issue
No it does not. The tuner is built in. That is why DTV is at the end of the model number.
1helpful
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
How do i convert my dtv-5801 to the new free digital air waves
My information indicates that the DTV-5801 has a NTSC (analog TV) tuner built in bot not and ATSC (digital tuner). It does have HDTV inputs to which an external tuner can be connected. For Off-Air Digital TV, add an HDTV (ATSC High Definition tunner) and you are set to go. Do not buy the DTV converters, they have down converters built in and only deliver SD to the outputs.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
