I'm using a PDT 6846 scanner. On initialization an error appears stating that the RF driver failed to load.
It can only be one of two things.
Less likely but also will cost you nothing, try and reload LWP and UPD but don't forget to use the comman FLSHFMT on both E drive and D drive first.
More likely is that the radio card of the terminal is busted or might have become lose as the internal radio connector was always a bit flakey on this device. You can try removing the 6 screws on the plastic cover, open it and unplug and plug again the radio card.
