Good morning my xerox 7700 is showing error code 14 which say cyan ATC sensor failure
That sensor is located in the developer housing. You can either replace the sensor, or replace the developer housing, which comes with the sensor. Either way, you will need to go into diagnostics and set the value of the new ATC sensor after replacement. (You will need to replace the developer powder if you get a new developer housing)
SOURCE: Error code 14-372 after power on
Chain 14 has to do with the scanner not passing self test, not comming to ready.
CCD Module, exposure lamp or one of the scanner baords.
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: error code 14
E-mail me at [email protected].
I can't post all of it on here.
Just put Phaser 7750 in the subject line.
