I have a cars tv dvd combi it all works button but the board wer the buttons are pushes back inside the casing wer are the screws to open it up to mend it any help would be appreciated thanks
    New Friend:
  • 30 Answers
There should be rubber stoppers on the back. They should be round or square. Pry them out with a small screwdriver or knife. The screws should be underneath the stoppers.
Posted on Nov 18, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: NOTHING WORKS ON DVD PLAYER
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Posted on Sep 26, 2007
Anonymous
SOURCE: DVD player reads open and the when I push the play button it reads invalid key
I am having the same issue with Toshiba SD-P1850
Posted on Dec 26, 2007
Anonymous
  • 148 Answers
SOURCE: dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Posted on Dec 29, 2007
hunhandad
SOURCE: u61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Posted on Jun 03, 2008
Brent
  • 46 Answers
SOURCE: DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Posted on Jan 20, 2009
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
DVD stuck in player. Now it does not respond to any buttons pushed.
Power up and press open button as soon as it starts to spin, some dvds lock with read errors, some spit the disc out..
If the belt is worn open unit, remove tray and replace rubber belt, if you dont have one use a thick rubber band.
if you cant access rubber belt, most dvd's have a slide underneath. use a small screwdriver and manually slide it open.
Read errors are not always the laser...so dont go and waste money.
If your dvd is not hq using dc brushless motors, remove loader, give the spindle and sled motor a good lube with wd40, spin the spindle moto up with 5-7 volts to clean the commutator.
Carbon builds up and the motors dont spin at correct speed.
Sled remove drive gear, usually pops out and burn it clean as above.
I have had good results with above since 2004, repaired 1000's of dvd's over my 14 years as senior engineer for wholesale importer in cape town.
Good luck
44ct357 CT SA
Jan 23, 2013 | Pioneer DV-C503 Multi-disc DVD Player
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
Remote control
Hi well I don't know the codes for the remote but I can help you find out if the remote is really working.All you need is a camera a newer one,one that has a lcd viewer,you have to point the remote end that you'd point at the tv toward the camera and push any one of the buttons on the remote,if you see a flash on the camera lcd screen.The remote is working,you can test all the buttons one at a time.First pic no button pushed,second pic button pushedI hope this has helped you.2_23_2012_2_51_58_am.png2_23_2012_2_52_25_am.png
Feb 22, 2012 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
How to remove the CD rom drive in a HP Pavalon slimline client?
See the panel on the side of the DVD Drive? remove that by lifting it backwards, it has a black button on top of it, remove it and now you have access to the screws on the side of the DVD drive, after unscrewing there's a button on the opposite side, push it sideways to unlock the drive and push the DVD drive out of the casing. Hope you figure it out.
Nov 25, 2009 | HP S3120N Pavilion Slimline Desktop...
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Sony dvd player cant eject disk
Sony dvp sr320 dvd player is working, but open buton then displayed lovked no open what can i do
Aug 11, 2008 | Sony DVP-NS575P DVD Player
TV wont turn off
IT COULD BE THAT THERE IS SOME METAL DEBRI IN BETWEEN THE TWO BUTTONS ON THE MOTHER - CIRCUIT - BOARD YOU CAN UNPLUG THE TV OPEN IT UP THERE IS I BELIEVE 4 SCREWS THAT HOLD THE BLACK COVER ON THE BACK THEN THERE SHOULD BE TWO BUTTONS THAT HOLD THE CIRCUIT BOARD PULL IT OUT VERY CAREFULLY AND LOOK OUT FOR DEBRI. YOU COULD CLEAN IT WITH DISTILLED ALCOHOL AND A SOFT BRUSH YOU WILL HAVE TO UNPLUG THE SPEAKER CONNECTOR ON THE LEFT SIDE ALSO ANOTHER CONNECTOR THAT COME FROM THE TUBE HOPE THIS HELPS
May 04, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
TV remote will not work properly
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
Feb 28, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
