Soda pop spilled on Casio 140CR electronic cash register and several keys won't work. Get an E08 code when pressing keys.
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
SOURCE: CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.-
Press the number 10801 and then press SUBTOTAL. Initialisation is
completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
