43-3808 After power outage we lost our dad's voice on outgoing message. He has passed away and we really want his recorded message on there, is there any way to retrieve it? Message machine has defaulted to the system message and we have not recorded a new message. Also, back up battery was replaced as well. Is the outgoing message gone for good? :(
SOURCE: greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
SOURCE: GE 29869GE2 Digital Answering Machine I lost the
Follow this link to download your manual.
Hope this helps,
Tom S.
SOURCE: I lost my manual and I don't remember how to
Select the model of your phone from the list at
http://uniden.com/index/manuals_results.cfm?cat=1
SOURCE: I lost the manual --
Since you declined to specify the model of your machine, pick the model from the list at
http://www.home-electronics.net/ge/pc/user-manuals.asp
