The A55-s1066 will not boot at all (no sounds fron the hardware, no display). All that shows up is the ambar ac light blinking (tried with and without the battery with and get same light blinking). No other light comes on. The amber light blinks with the follwing pattern repeated ( I guess this is the diagnostic code for what is happening). short blink - short blink - long blink short blink - short blink - long blink short blink - short blink - pause then repeats above cylce again.... Does anyone know what the code is for? What is the problem? Is it a bios problem? hardware? software? battery? Should this model boot with the ac power adapter and no batter? Please help I dont want to take it in to repair without knowing what is happening,,, Thank you for your help and suggestions!! dserrano4
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
