Computers & Internet Logo
A
Anonymous Posted on Jan 25, 2018
TOSHIBA SATELLITE A55-S3063. This computer will not turn on. When I plug the power the amber light will start flashing but will not turn on. With or without the battery, will not turn on. The charger is working good, it got tested. The plug in the laptop is nice and firm, checked too. PLEASE HELP!
Larry Ng
Level 3:
Top Expert:
  • Toshiba Master 14,591 Answers
  • Posted on Aug 26, 2018
Larry Ng
Toshiba Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3277643
Points
66570
Ok like all old laptops the CCFL lamps are now dead.
all are. if used every day and 20,000 hours hit, bam DEAD.
the CCFL are dead,
all LT made before 2010 had CCLF back lamps.(and monitors)
you hear the fan blow?, and no text on screen? (2 things)
your 14year old (today) the screen CCFL lamps are bad.
do this, 5 minute work. ok> and tell what fan does.?????
http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
5 Related Answers
Gino Felina
  • 81 Answers
  • Posted on Sep 05, 2008
SOURCE: Toshiba Satellite 2410-PS241L laptop does not start.
Plug it into the electrical outlet and then turn on your laptop. if it comes on and works fine, then your battery is just simply dead, and if it will charge, just needs to charge. If not, then you are going to have to replace your battery. But assuming all of this is true, and your laptop will power on when using your electrical outlet, then yes, feel free to use it whenver you like when plugged in.
Anonymous
  • Posted on Dec 10, 2008
SOURCE: Toshiba Satellite A55-S306
Hi Sacnyc,
Very first thing, is send me the picture of your DC jack and adapter. I have repaired A55-S306 more than 10 times, and can replace your DC jack if its bad..
Anonymous
  • 104 Answers
  • Posted on Aug 01, 2009
SOURCE: my toshiba satellite A135 doesn't power on, it
clear the cmos(bios), you must unplug the battery on mainboard(if you are an expert and you can open the laptop) for 10 hours (or short it) then power the laptop.
Anonymous
  • Posted on Feb 20, 2010
SOURCE: toshiba won't start
my laptop toshiba satellite start,power led is on but the screen stay black.i,ve try to remove ram an hard drive and put back but have the same problem.thank you.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jul 16, 2011
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
BATTERY LIGHT FLASHES AMBER
I think when I Toshiba laptop does this it is indicating the battery is extremely low or not charging correctly. I would try either charging or changing the battery.
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
My toshiba sattellite a55-s326 has a flashing yellow light but won't power up.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Hope this works
1helpful
Support updates does not list my Satellite A55-5326 on there sight. My light is flashing and will not power up.
how many times? 1, 2,3....
maybe battery dead or hardware problems, you can tell-me how many times flash and is a code with 3 digits, like morse
2answers
No Power Toshiba A55-S1063
sounds like the powersupply might be bad try another one if that dont help then your board is bad -sorry
1helpful
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
