Question about Vision Fitness 2011 Vision T9800 Hrt Treadmill
My vision treadmill T9800 HRT when start shows speed stall and error 7
    Top Expert:
  • Vision Fitness Master
  • 12,223 Answers
Please see the 2 alternatives for error 7. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Sep 20, 2013
6ya staff
SOURCE:
Stuck key error on my treadmill
Sometime talcum powder under the thread will get it working again, but you may eventually need a new tread. Less likely, a problem with the motor especially if it's underpowered.
Jul 31, 2016 | Vision Fitness - T9800 HRT Full Commercial...
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
2)Alternative:
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    What is error code e4 on vision fitness t9350?
    I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
    It runs up the speeds and back down but then stops without ever showing 'end'.
    When i then take the safety key off and replace it the E4 error code shows again.
    The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
    Any advice?
    Feb 18, 2012 | Exercise & Fitness
    Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
    Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
    STEP 1 ENTER ENGINEERING MODE
    With the safety key in place, hold "ELEVATION UP" and "SPEED
    DOWN" buttons for 5 seconds. Software version will appear in display
    window for a few seconds before model displays.
    Press "STOP" , "ENG1" will appear in display window.
    STEP 2 AUTO-CALIBRATE
    Press "ELEVATION UP" until "ENG4" is displayed.
    Press "SELECT" , display will read "AUTO".
    Press "START". Unit will calibrate, when finished "END" appears in
    display window, then "ENG1".
    STEP 3 EXIT ENGINEERING
    Press and hold "STOP" to exit engineering mode
    I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
    If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
    Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
    My cardio zone club max hrt speeds up and inclines on its own. How do I fix it?
    When i turn in my Cardiozone Club Max Hrt. it starts showing SI 2.
    Feb 11, 2010 | Cardiozone Exercise & Fitness
    Vision Fitness 2011 Vision T9800 Hrt Treadmill Logo
    303 people viewed this question
    Top Vision Fitness Exercise & Fitness Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    ray gallant
    Don Eagan
    Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
