Have you been able to configure a WiFi profile using the on board utility?
If not and if you don't have the icon at the bottom right of the screen you will be able to find it in the windows folder.
If you have a profile setup, does it have a yellow ! icon on it if so, use the icon on the bottom right then> options > Regulatory in the drop down menu > and untick 'Enable...' box
If you have DHCP setup in the profile you may not be getting an IP address, you can check this in the status option from the pop up menu (bottom right).
if you are not getting an IP Address, check all your settings in your WiFi profile.
I normally start with a un-encrypted network to test the unit, then add encryption after you get it all working. You will need admin rights for the AP you are using.
Additionally i have found that some units don't like TKIP type networks with out a software update.
Hope this lot helps.
