SOURCE: White screen, won't take pictures, battery door won't open!!
The LCD screen has just come unattached. Take a pencil with an eraser and press on the lower right corner of the LCD screen. You may have to tap it once or twice, but the screen will come back on. As far as the battery door, it sounds like it is stuck on something. Might want to try tapping the end of it to see if it comes loose.
SOURCE: lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
SOURCE: Camera jam
All the R series Ricohs have a pretty complicated lens system employing 2 swing-out lenses which can get stuck pretty easily, or worse, broken. If you are very good at taking things to bits you might have a go at fixing it (I've done several that were not TOO bad) since picking up one on Ebay with a good lens unit is almost impossible.
