SOURCE: install 2 ton 13 seer
Goodjob, now check the valves stems for leaks.! .....Thank-you-very-much!
SOURCE: electric coil in a 7 year old unit continues to
most likely couse is the indoor fan stops working
the elements get to hot they should be a safty for each element some snap to open the circuit
or they have things that look like gray resters
that may be open but you can not tell witch an ohm meter to check if they are good
SOURCE: leak found in evap coil.
im not sure what your seer is or the type of freon you have in it this coil may no longer be available I would need more info
