Radio Communications Logo
Ken Winters Posted on Sep 20, 2013
Need manual for regency turbo scan 800. - Uniden Radio Communications
Laurin Cavender
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 17, 2019
Laurin Cavender
Contributor
Level 1:
Answers
Questions
0
Helped
679
Points
8
I have Manuals with the update Sheet $14.95 each (706)270 3829
1helpful
Where can i get a 110 power reducer for a Regency turbo scan 800 scanner
try scanner master first and do a google search forpoer supply for your model
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
1helpful
Bought a used BBQ Galore Turbo BBQ CG4tdbrn
Hello, I wasn't able to find a manual, but I did get the manufacturer's toll free customer service # 1-800-752-3085. See what they can do for you.
1helpful
I have a older uniden bearcat BC860XLT and dont no how to program
Programming steps and many other questions can be answered in the scanner's operating manual, which can be downloaded/printed here:
http://www.uniden.com/pdf/BC860XLTom.pdf
Bill B
1helpful
I have an Old Regency Toutch K 100 20 CH S1&S2 S1 is 1-10 CH ?? S2 Ch 11-20 is that correct?? or do you also use CH 1- 10 on S2 ??? What is a Code '' d '' It will not scan all 20 Ch only S2, and not...
The K100 is an oldie from about 1980, when Regency was still manufacturing some radios in the USA and importing some from Japan. Below is a link to the manual for the K500, which had more channels & features than the 100, but was a similar radio. There is currently an eBay listing for the K100 manual (pdf) if you want to spend a few bucks.
http://www.repeater-builder.com/relm-regency-wilson/regency-touch-k500.pdf
2answers
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
4helpful
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
2helpful
I dont no how to program my regency z30 scanner
1. Press "MANUAL"
3. Press "ENTER"
If you wish to add more frequencies at this time, got to step 2.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
FINDING FREQUENCIES
87ff97c.jpgNo it can't sorry. If you want to scan things all the way up to the 900 MHz frequency you should get a Regency Touch K500. Its not a portable scanner however. It may be a little hard to find because Regency went out of business a while back, but look on e-Bay you'll find it there.
1helpful
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
