Question about Ricoh Aficio CL2000N Laser Printer
Ricoh nrg c7521n error cc 230 - Ricoh Aficio CL2000N Laser Printer
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
How do i fix error code SC 230 IN MY PHOTOCOPIER RICOH AFICIO MP 5002SP
Common causes are sync detect board, laser diode unit, BICU, Power Supply and wiring problems.
Mar 10, 2016 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1015. Why is it not resetting?
Code 543 - Description: Fusing overheat error.
A fusing temperature of over 230°C is detected for 1 second by the fusing thermistor. - Causes: • Fusing thermistor defective • Power supply board defective
May 28, 2015 | Ricoh Aficio 1015 All-In-One Laser Printer
Ricoh NRG MPC2030 does not print PCL windows 8.
Guess youll have to wait a little until its offered. It seems Windows 8 is having many dislikes. Try contacting Ricoh for new Windows8 drive.
Jul 24, 2014 | Ricoh Aficio Office Equipment & Supplies
I need win7 driver for DSc428
http://support.ricoh.com/bb/html/dr_ut_e/nrg/model/c35_45/c35_45en.htm#Microsoft%20Windows%207
Jan 28, 2013 | Gestetner DSc428 Color Copier
I need some solution for the error code for ricoh aficio 220,the error code was SC 543..can you help me for this problem..tnx..
Symptom:
Detected fusing temperature
remained above 230°C for 1
second.
Possible Cause:
• PSU defective
Nov 22, 2010 | Ricoh Aficio C811DN-T1 - printer - color -...
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
553 is:
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1
second.
�� Defective PSU
�� Defective IOB
�� Defective EGB
These codes related to the fuser a designed to prevent a fire
I would recommend haveing a tech look at it
Nov 08, 2009 | Ricoh Aficio SP C811DN-DL Printer
We need a manual for the NRG D422/2822/3222 PCL printer. Do you know where I can get this? thank you
Here's a link to the Ricoh version (aficio 220). It's the same machine. Only the Copy" manual is available, not the fax: http://www.ricoh-usa.com/downloads/manuals/bw/aficio220.pdf
Jun 04, 2009 | Office Equipment & Supplies
Ricoh Aficio CL2000N Laser Printer Logo
107 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
