Question about Kodak EasyShare M863 Digital Camera
KODAK M863 LENS STUCK
My kodak m863 has the lens stuck in the out position, and wont retract. .also wont turn on.. is thier any repair possible
thanks
  • 1 more comment
  • sexxyvee028 Apr 22, 2009
    I have the same problem. I was using the camera to upload my pics to my computer, then unplugged it from the usb cord and the lens would not retract. I waited a few minutes and still the same problem. Called Kodak and they told me to fully charge it for three hours. I did that and the lens still did not retract. The little green light just kept blinking and the camera would not turn on when i pressed the power button. Ultimately i ended up breaking it because i pulled on the lens too hard and the front came off. Have to buy a new camera, and i definitely will not beb uying a kodak anytime soon. By the way i had the m863 model.
  • allanbanfiel Apr 26, 2009
    dont think your camera is broken just because the front part of the lens has come off, got my camera to retract lens and work for a bit by slightly rotating the lens. .the front part can detach and you can re attach it by lining up the pins so they go back into the slots..
    unfortunitly when i use the zoom i end up with the same problem for lens not retracting and wont turn on. .
  • Alex line Sep 12, 2012
    i have the same prob as suzainnevhie
  • 4 Answers
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Posted on Aug 16, 2012
My kodak m863 fell,and then the lens is stuck!do you think it can be repairable??
Posted on Jul 31, 2009
Anonymous
SOURCE:
Light blinking after LCD screen replacement
Go to Kodak site and find out the significance of the blinks and you will be guided accordingly.
Sep 03, 2017 | Kodak EasyShare M863 Digital Camera
When I turned off my Kodak M863 the lens did not retract and now the camera will not turn on.
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 21, 2010 | Kodak EasyShare M863 Digital Camera
M863 lens extends and then immediately retracts
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
Jul 24, 2010 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
Kodak M863
Clean the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Do the same to the battery and the charger.
Oct 07, 2009 | Kodak EasyShare M863 Digital Camera
I have a Kodak M863 camera and it wont stay on
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Sep 29, 2009 | Kodak EasyShare M863 Digital Camera
Lens wont stay open.
Remove the battery
Contact KODAK OoW repair is 48,44 +shipping to the repair centre:
Aug 03, 2009 | Kodak EasyShare M863 Digital Camera
Camera wont Turn On
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EASYSHARE M763 Digital Camera
Lens is stuck
Time for a new camera, the cost of repair is way beyond value of this camera.
Jul 01, 2009 | Kodak EasyShare M863 Digital Camera
Jammed Camera Lens
My camera lense is stuck cause i jaut accidently leaned on it and it's stuck and won't come out.!
What should i do.?
May 29, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
2,217 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
