Question about Samsung LN-R3228W 32 in. HD-Ready LCD Television
Just bought a Samsung LCD tv, 32" 2 days ago and it worked fine yesterday but today it keeps turning on and off by itself but even when it turns on, no picture comes up. Tried resetting it (unplugging and disconnecting cables, etc). Nothing seems to be working. The bleeping it makes when turning on and off is driving us mad.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
Hmm...I have been in the repair business for 20 Plus years now and it is now coming to my attention that fake parts are being manufactured, what is cool about electrolytic capacitors is that they have the ability to heal themselves, they can cool down and work for a while, but mainly they just explode, I would guess that the low dollar vendor for the capacitors on this run of televisions went to the low bidder or they have gotten a hold of some miss labeled capacitors, right capacitance, wrong voltage, an it could be a run of sets designed to work on the lower voltage standard in Japan, anyways these have found their way into your sets, and they cook for a year and pop, it is usually an easy fix, but most do not understand this, I guess the cheapest model is the best, instead of buying products that will last you 10 years, you get to buy it 5 times now,,,treat your enemy well and treat your brother like ****, I guess we get what we pay for.
Posted on Oct 21, 2010
I have found a solution!
There is a class action settlement against Samsung and they are willing to fix problems on certain models mad during certain dates here is the link: http://www.samsung.com/us/capacitorsettlement/ I have just gotten off the phone with them and they will be sending me a technician next week to fix the problem.
Posted on Nov 30, 2012
If the tv is shutting off while using wifi (Netflix) for some reason the tv shuts off if the signal is weak. Plug in an Ethernet cable or move your router closer
Posted on Dec 07, 2012
I just unplugged the tv from the power strip directly into the wall and the problem of tuning on and off seem to have solved itself out
Posted on Sep 08, 2012
I bought my samsung 40 8000 series 2 weeks ago, I have had an issue with the blue standby light not working as the manual says it should as it has 4 different ways of viewing it ( i know it sounds over the top for a standby light)
Anyway this morning my wife went to turn the tv on and it turned itself straight off, the remote was completley unresponsive and I reverted to unplugging it and then back into socket and it came back on. I am a real fussy bugger and this kind of problem really gets to me as I saved for 6 months to buy this tv and now not sure what to expect on a daily basis. Take note Samsung your new LED TV;S are having issues you must investigate, release firmware or some kind of fix, customer loyalty is most important, tony.
Posted on Jan 17, 2010
My 40inch does it too. I called out the geek squad for the warranty repair and all they did was update the firmware. I called them again and they found nothing. Now since I did some research, I have called them for a third time and told them what I found. Can't wait till they get here. I am sure they are gonna come up with some techno mumbo jumbo to sound smart. But as long as it gets fixed that is all that matters. I have 4 more years to bug them every day just to make them come out and check it.
Posted on Mar 14, 2010
Press menu on the remote, go to system,
check timer-should all off
check eco solution-should all off
check auto protection time should all off
=if issue not resolved tv need for repair
Posted on Dec 28, 2014
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:12.0pt;"Times New Roman"; mso-fareast-"Times New Roman";} I am here to do two things, chew bubble gum and solve problems, and I'm all out of bubble gum. My tv had a similar problem and I have found a quick but temporary solution. On the back of my 32 in Led smart tv I found a plastic removable cover. It is right below and the "component-in" accessories. Before removing this cover make sure that you unplug the tv so you don't get electrified (before unplugging your tv make sure that the power is on, this is important for later steps) . 1. Remove the cover with a phillips head screw driver and you'll find a wire harness strip that is connected to the tv through a white clip. These wires lead to the tvs manual power button and the tvs LAN wireless receiver. 2. Pinch the sides of the white clip and remove it. You should be able to do this without taking off the entire back of the tv. 3. Once you have unplugged the wire harness, plug your tv back into the wall. It should turn on by itself if the power was on before you unplugged it last. 4. Your tv should be working better without the LAN and Manual power Connected, however you need to reattach the wire harness the enjoy your. Once all these steps have been executed properly your tv should be returned to its usually working order. Reattach the cover and resume enjoying your smart tv. The quick fix should last a couple days.
Posted on Apr 09, 2014
Johnocz - THANK YOU SO MUCH. I have my PS3, blu-ray player, UVerse cable box, speakers and TV on the same circuit and power strip. I moved the TV to its own socket/power strip and the problem's solved. GREAT advice!
Posted on Nov 29, 2009
Nov 16, 2015 | Samsung Televison & Video
Aug 23, 2013 | Televison & Video
Aug 26, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
Apr 29, 2010 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Mar 03, 2009 | Samsung LN46A850 LCD TV
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
May 20, 2008 | iLO 3200 32 in. LCD Television
26,621 people viewed this question
My Samsung LN-T2332H 23" LCD TV, continuously turns on and off by itself. It did it a couple of days ago, then started working for several hours, but then the problem started again.
Bought our 40" Samsung LCD TV, 530 model last week and it too turns on and off by itself ... middle of the night, middle of the day, will turn off while you are watching it. Sometimes will turn on and then off again within a few minutes, sometimes will turn on and stay on. Retailer could not offer explanation other than "bring it back".
my samsung 23'' tv turns on and off by itself every 1 minute
I have the very same problem. Bought a 46" Samsung LCD HD TV at Futureshop 2 weeks ago (LN46A750). It was working fine until this afternoon when I have to turn it on, there is no display and it will turn off and on again by itself. It pisses me off. Fortunately I could return it back and have it replaced. But I already have doubts now with Samsung knowing now that this is a common problem and several users had this already.
Same problem on 40" model. I called Samsung and scheduled a tech to come to my house. He called before coming to verify what the problem was. After explaining the problem to him he said that the main board would have to be replaced. He also told us that this is not the first time he's seen this problem with a samsung. He recommended returning it since we had bought it a week earlier. We finally returned the tv and bought a Toshiba 46" for the same price (from wal-mart). I actually like the Toshiba better.
We have the same thing going on. Some days it works just fine and others, it turns itself off every few minutes. Best Buy said we couldn't get a warranty because it was a display, then when I called to tell them what was going on, the guy laughed at me because I didn't get a warranty! GRR! He said it would cost close to $200 to send a tech, then however much parts would cost! Samsung has to be responsible for repairs SOMEHOW!?
same issue. Samsung sent someone out to repair but they replaced parts that did nothing to solve this. Tech said they did this due to recall and it will not fix. Cost to repair- $321. For that I will be any other HD TV BESIDES Samsung
Hey yall, I just figured out how to fix this. On my Samsung 32 inch led tv I was having the same problem. On the back of the tv there is a plastic cover with a screw attaching the cover to the tv. If yours has a similar cover, take this cover off. You will see a strip of wires connected to the tv through a white plastic clip. With the tvs power unplugged, disconnect the wires from the tv. These wires are obsolete to the general functionality of your television. Once you've located and unplugged this wire strip, plug your tv back in. This solved the problem for me for a couple days, but this step will need to be repeated once your tv goes back on the frits! The wire strip connects the tv to the LAN receiver, the manual power and the remote control receiver, so you have to plug it back in if you want to use these accessories. Hope this helps you out and good luck nerds.
