Samsung Digimax D53 Digital Camera Logo
alan o'brien Posted on Sep 22, 2013
Camera has charged batteries. at first when i turned on power...nothing happened...then...later...i pressed power again and it came to life. the lens popped out and i took a bunch of pics and reviewed them. then i turned it off....AND now when I press power button, the green light comes on for 5 seconds, then goes out...and I hear three sound tones...and it shuts off. i cannot get power button to work accurately. please help!!?? this is the correct model...digimax D53
rey manalo
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Apr 16, 2014
rey manalo
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
288
Points
24
@ alan o'brien, Samsung D53 digimax draws a lot of current from the battery thus, you need to replace your batteries with a HIGHER current ratings, sufficient enough to run the motor. This miniature motor inside the D53 camera drives the reduction gears functions, to extend and retract the mechanical lens. During this processes it is drawing a lot of current from the battery. In order to conserve and prolong battery power avoid zooming in and out, utilize the function speed 50-400 and manually adjust aperture to minimize the unnecessary use of flash. In other words, go manual mode. Here's the battery specs. 2800ma NiMH rechargeable battery. Refer and follow manufacturers recharging instructions for best result. Do not leave batteries inside the camera even when not in use because the circuit inside is still on the standby mode and not necessarily off. Hope i have satisfy your curiosity. If you can, kindly share with me some of your best photo taken from your D53 digimax. Thank you.
5 Related Answers
Anonymous
  • 107 Answers
  • Posted on Feb 27, 2007
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
howisland
  • 6 Answers
  • Posted on Feb 24, 2009
SOURCE: my samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Anonymous
  • 2761 Answers
  • Posted on Oct 31, 2009
SOURCE: Hi---our Digimax won't stay powered up, even with
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Anonymous
  • 6831 Answers
  • Posted on Sep 05, 2010
SOURCE: Samsung PL150 shut down after starting up, lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
I have an canon a480 camera. I have the problem that even if I charge my 2500mah batteries, when I again turn on the camera I see the low battery sign flashing on the screen? (When I press some of the...
Are the batteries old and been charged many times? Have they ever been allowed to sit around for a long time and completely discharge (which will shorten the life and prevent full recharge). Have you tried cleaning the contacts in the camera with a cotton swab lightly dampened with rubbing alcohol?
1helpful
My R607 BMW camera doesn't turn on. I got fresh new battery in it newly charged but when I try to turn it on nothing happens. It's been sitting unused for probably 2 years or so but it worked then so not...
You should reset the camera:
-Hold camera upside down -Open battery/card door -Remove card -Remove battery -Make sure A/C power is DISconnected -You should see a small hole above and to the right of the battery slot, insert a sharp object and press -Re-insert card and battery
If this does not work, try it again a few times, if still unresponsive, the camera may need to be serviced by HP.
2helpful
When I push the off/on button, nothing happens. The battery is good though. It worked great since Dec 2009, but in the past month this has been happening. Thanks.
For clarification, how many years that you have the camera. Did you already changed for a new battery? Is there any incidents that you dropped the unit?
First make sure that you properly inserted the battery, check the electronic contact for any dirt/rust on the battery and to the tray.
Battery life can be the issue here, if you have not yet change the battery try to change or use new battery. In some cases like this battery cannot hold anymore power when you try to charge it.
It defends how frequent you use the camera, as long as you use it it will also shortened the battery life.
Let me know here again for further more assistance.
Thank you for using fixya.
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
1helpful
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
88helpful
10answers
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
2answers
Will not come on at all
After a hard reset you must do a soft reset to enable the battery.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
