SOURCE: Need a Replacement LCD Panel Module for a Sony Bravia KDL-32S2000
I don't have a listing for the model that this is posted under, but the replacement panel for similar model KDL-32s2010 is $2232.55
I would expect the cost of your replacement to be similarly priced. If you post your specific model, I will attempt to get the exact price and part number.
Dan
SOURCE: My Sony KDL-46 Xbr4 picture flickers and there's
The blinking light is a problem code.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you blinking light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
SOURCE: What does the six blink error code mean when on a
6 blincks is protection code. Service tech needs to diagnose problem because failure could be from inverter board to panel itself.I'm sorry I can't do better than that.
