Have just upgraded to Windows 7 and now I am getting the following message "The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)". Can you advise what I need to do to get my DVD/CD tray working please?
SOURCE: Toshiba A305-6825 laptop prolem (no
You seem to be onto things (though your problem classification was generic instead of for your Toshiba model A305.) Install all the updated drivers for your laptop from the laptop's support site (Toshiba's, that is) so you can use your drive. Drives fail sometimes, and you could try sticking an old movie or something in there instead of nothing, but it is likely it is just the missing driver.
SOURCE: HL-DT-ST DVDRAM GSA-T20L ATA Device
Check the jumper on the cd/ dvd rom drive. maybe it was still there. I tried before to remove it. The os installation continued after i Removed it.
SOURCE: code 39 error, not working driver corrupted
DisparitionCD was the answer. thank you. A setup information software from the internet.
SOURCE: HL-DT-ST DVDRAM GSA-T20N ATA DEVICE driver error code 39
Hello Matoooon,
Run this following fx and then restart the notebook, the DVD drive will start working normally.
http://www.jasonross.name/files/CD_Drives/CD-Drive_Fix.reg
SOURCE: HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
