Motorola Mobility H350 Wireless Headset Logo
Posted on Sep 18, 2007
Setting up my H350 on a new phone
I received a new SAMSUNG SGH-A707 and either it or my Bluetooth won't link up. I search for new devices on my phone, while the bule tooth is on and I get the No Devices Found. I've tried turning off my headset, putting the phone in search, then tuning on the headset. I've tried headset already on and searching.
  • 4 more comments
  • Anonymous Nov 19, 2007
    I have the Samsung SGH A707 phone, and book, but I lost the book for my H350 headset. I just need the pairing instructions for the headset.
    Thanks,
    Mark B.
  • Anonymous Dec 15, 2007
    CAn find the headset... requires a pass code and says connection failed
  • mel04 Dec 27, 2007
    i have a motorola L6 with a H350 connected and a L2 with a H350 connected i want to swap them around and i can not do it the phones only pick up the ones that have been used on there phones is there any way to wipe the mem of the headsets
  • bluestooth Jan 14, 2008
    I have the same problem. my phone just searches and wont find the H350 headset that is sitting right next to it. Its very frustrating
  • Anonymous Jan 18, 2008
    how do i set it up
  • Frustrated11 Feb 11, 2008
    Have a Samsung Z230.
    Once it found it I keyed in the recommended pasword 0000 but no connection generated.
    When trying again it searches and searches and searches the H350 and does not find it.
    After a while the H350 shuts itself down.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
115
Points
5
When hooking up your bluetooth hold your volume and your call button at the same time. .then your head set indicator light stays on .then you can set up your phone,your phone will ask for a code the code is 0000 that will set your headset to your phone.
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
2answers
Cannot transfer names to toyota navigation system
Hi Friend,
Go to setting----> connectivity------>Bluetooth------>My phone's Name
erase the previous name and type the required name
Regards,
Ayyasam
1helpful
Our SGH-c417 Samsung cell phone will pair easily with a bluetooth headset but with our Toyota built-in bluetooth handsfree headset, it will not pair. It just searches and searches and never finds the...
I have had a similar issue with SGH-A707, I have found that taking the device out of discover mode, then removing the battery from the phone to reboot it. once booted, turn on the bluetooth on the phone and put the device into discover mode. Should find it.
2helpful
I have samsung sgh-a707 phone cannot pair plantronics 521
I have samsung sgh-a707 phone cannot pair my new plantronics 521blue tooth.I search but get "no devices found".is it the phone or bluetooth?Help
1helpful
How to link my phone to my bluetooth
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Motorola H350 connecting to my samsung
well idk cuzz i cant connect it with my samsung SGH-A707
2answers
Bluetooth
removing the bluetooth is as simple as this:
menu, settings, connectivity, bluetooth, my devices, press down to get to the device you want to delete, press options, then delete.
h700:
menu, settings, connectivity, bluetooth, my devices, (should have at the top: search for new devices scrolling). Click that:
h700 bluetooth should be in pairing mode:
hold the center button down and wait for it to turn solid blue: the go back and search for new devices on the phone, when it finds the bluetooth, enter 4 0000 zeros for the passcode. The click if you want it to automatically connect or not.
Your done!
Clint Cartee
2helpful
2answers
Sim card transfer
depends on the phone you are using to transfer from. On my sony, for example, i can go to my contact list options and send contacts via bluetooth to another device.
Which phone are you sending from?
1helpful
How do i connect a blue tooth to my SGH-A707 phone
well the way i know to do it is if you want to ues a bluetooh headset is to turn the headset on then go to connections go to bluetooth then go to my devices and search for new devies(note* make sure your phone visibility is on)
Bluetooth
It is really simple, go to settings, connectivity(6 down), then hit bluetooth, then activation on, then go back to the the display were it says Activation, My devices, My phones Visibility, Ect. And go to My Phones Visibility and make sure it is visible, then go back to the page with all the bluetooth stuff, and go to my devices, and search for new devices and it will search and you should see your freinds phone if they are next to you. and i got to go eat thanksgiving dinner so if you cant figure the rest out e-mail me at [email protected]
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
