SOURCE: audio driver problem
You should install the Chips drivers or intall all the driver in series listed in your CD Utilities. Its good if you download the latest drivers of your system at www.asus.com or here: http://support.asus.com/download/download.aspx?SLanguage=en-us
You should download for 64x2 drivers.
SOURCE: asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
SOURCE: ASUS M2N-MX SE Plus mother board windows 2003 audio drivers
It is better to install windows xp..
because 2003 is not supportting latest mother boards.
only windows xp will solve that problem
thank u.....
SOURCE: audio driver installation
Try downloading lastest audio driver from Asus.
