HELP Please....5 boys no washer lol ....Bosch washer 100 series - wont reset- finish light, spin light and wash light all blinking- cleaned out filter - tried unplugging and plugging back in........while holding start/pause button on spin/drain and tried holding rinse/delay buttons while turning to cold/warm cycle..any other suggestions (warranty expired) it was fine until the door wasnt closed all the way this morning when I hit start and my son opened it to reclose instead of just bumping the door closed fully and then it wouldn't start.
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: I tried to wash an
Is it flashing only E or there is a number besides it such as E 03 or E1?
Thanks and Regards
taran_2005
