RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
Posted on Apr 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Grey spot on screen
I have a 61 inch dlp that has a grey spot on the screen. We have no idea where it came from or how to get rid of it. Does anyone have any suggestions???
  • 1 more comment
  • punkinn2u Apr 19, 2009
    it looks like someone pushed up against the screen. But no one was that close to it. It is a blob type circle...ish It just popped up today. The tv has been on all day and we were wondering if it might be the lamp??
    How do I take the screen off of the TV???
  • Anonymous May 11, 2010
    How big of a spot ? Is it a blob or is it symmetrical ? Did it show up slowly over time or just pop on screen one day ? I might be able give you an guess with these answers.
Anonymous
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
17067
Points
118
It's not the lamp. It maybe dirt or dust or even a bug. The picture that is projected starts out 1/2 inch by 1 inch in size. Somewhere along the path to the screen a piece of dust gets in and after it's projected it looks like a blob on the screen. The closer it is to the DLP chip itself the bigger it looks. If this is the case you should have a professional service it. The Light engine needs to be removed and cleaned.
If you lightly push on the screen does the blob move slightly ? If it does it's not on the screen it's in the optics or the mirror.
You may also have a bug or smug on the main mirror that causes the same thing. This will appear about 2 times the normal size of the object. If your up to removing the screen Take a look closely at the mirror on the back of the set. You can clean this with windex it's glass. If you do take the screen off hold it up to the light. Sometimes spiders make webs and leave marks.
Good Luck
DLP chip replaced, now black screen and error code 61
Could be bad conections, I gues. I have downloaded the service manual of: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf In manual you can find more information about the problem. Luck! http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf b16238c1-e835-41b2-9320-a038bc07b019.png c23b3cd8-57ed-484d-b6b2-3c2c86547319.png
How to reset a 61 inch rca dlp television
To my knowledge none of their DLP's have a reset feature--what is the set doing or not doing?
My 61 inch sony DLP ,i think a '07 just black out
You check the power supply section and the horizontal section
2helpful
Small white spots appearing on T.V. screen.
The DLP chip is failing and will have to be replaced. Samsung is covering the cost of repair for this problem on SOME models. You can call 1-800-samsung to find out if your unit is covered or to find the nearest service center.
3helpful
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Used air spray to clean samsung dlp 61 inch. know have spots on screen how do i clean this
you will need to disassemble your set and clean the light engine as dust has entered from using compressed air
1helpful
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
