I am afraid I do not understand. The frequency of a PARTICULAR score is the number of times that particular value occurs in the data. It is not the number of data.
Ex: the data are:
4, 6, 5, 4, 4, 8, 9, 3, 3, 6, 7
Frequency of (3) =2
Frequency of (4)= 3
Frequency of (5) =1
Frequency of (6)= 2
Frequency of (7)=1
Frequency of (8)=1
Frequency of (9)=1
Number of data =11 (n=11)
You compute the mean M
M= (2x3 + 3x4 +1x5 +2x6+1x7+1x8+1x9) /11 =5.363636..
As you can see, if a term is not repeated it is multiplied by 1 (its frequency is one). Value 3 occurs twice (hence 2x3); value 4 occurs 3 times (3x4), etc.
To calculate by hand the sum of squares
3: (3-5.3636)^2 + (3-5.3636)^2 .................... =
2x(3-5.3636)^24: (4-5.3636)^2 + (4-5.3636)^2 +(4-5.3636)^2 =
3x(4-5.3636)^25: (5-5.3636)^2 ...................................... .=
1x(5-5.3636)^26: (6-5.3636)^2 +(6-5.3636)^2......................=
2x(6-5.3636)^27: (7-5.3636)^2.......................................... .=
1x(7-5.3636)^28: (8-5.3636)^2......................................... ..=
1x(8-5.3636)^2
9: (9-5.3636)^2......................................... ..=
1x(9-5.3636)^2If I have not made a mistake the sum of squares is 40.5454
Standard Deviation The standard formula above gives s= square root (40.5454/10) =2.01
Population Standard Deviation The population Standard deviation above is S= square root (40.5454/11) =1.9198
So if you perform the calculation with the calculator the only times you need to enter the frequency is for repeated terms. When you have to enter 6 above, its frequency is 2 you proceed as follows
6 [2nd][FRQ] 2 [Sigma+]Once you entered the raw scores, the calculator does the rest.
Hope it helps.
